I'm wiring an IR LED driver for an Arduino project I'm prototyping.
The Arduino will be run at 5V, and I'm planning on using it's 5V output to drive the transistor that runs the LED
The circuit I've found uses an NPN transistor with the gate controlled by a digital output from the Arduino. The digram has me wire the 5 volt supply through a current-limiting resistor, the IR LED, and into the collector of the transistor. I'll call that resistor R1
The emitter is wired directly to ground.
The base of the transistor is wired to the output from the Arduino through another resistor. I'll call this resistor R2.
The LED I'm using is one I bought from Radio Shack. The package says it's maximum current is 200mA, and the supply voltage is 1.2 volts.
A quick calculation with Ohms law tells me I should use a 50 ohm resistor to limit the current to 100 mA. (r = v/I, 5/.1 = 25).
I have no idea how to figure out the value for r2, the resistor from the Arduino output pin to the base of the transistor. If you look at the circuit below, it calls for R1 = 10 ohms, and r2 = 47 ohms. I don't know how those values were derived, or the rating of the components those values are intended for.
That circuit calls for a 4.5 volt supply to both the Arduino and to the transistor. I'm using an Arduino Mega, and it calls for 7-12 volts input if you're feeding Vin, or 5 volts regulated from a USB port. It has a regulated 5 volt output with enough current to drive my transistor and LED.
Can somebody help me figure out the values for R1 and R2? I'm using a scrounged-from-my-parts-drawer NPN switching transistor in a TO-92 package, either a 2222A or a C1740.
