I designed a Constant K (I don't remember the constant K) LC band Pass filter with lower cut off frequency 1 KHz and upper 5 KHz. Using the value of K, I deduced the values of L and C and made the following circuit:
I've used R1 = 999999G to show infinite resistance.
I carried out the AC sweep (frequency response) in PSpice and got something like this:
Is the graph correct?
Also one more thing I want to ask is that, can we get Vout (output voltage, the green probe in the circuit diagram) more than 5V i.e. the input voltage?
