I understand that what I am doing requires the utmost care and that numerous precautions should be taken in completing a project like this.
Out of necessity, I am going to fashion a car battery charger from an ATX PSU. I need to draw ~14v to do this, I'm guessing from the +12v rail.
How can I tell if this will be possible for the PSU I have?
What I know:
- This model uses HA17431PNA shunt regulators, which I have located on the circuit.
- I will need to modify that IC's input circuit to adjust the regulator's voltage.
- This may also require me to adjust the output caps, but given the step-up value it also may not.
What I don't know:
- Precisely how to tackle this -- I have a decent soldering station and resistors, but this would be the first time I worked on something other than a phone/doing rework. I found the spec sheet from Hitachi for the regulator. What other resources should I consult?
- What generates DC from AC in an ATX PSU? A transformer? Is the transformer able to generate this voltage for me without affecting other components?
- How this will affect the current output on the rail.
- Any other unknowns regarding how this modification might impact the performance of the PSU.
Can someone please help me accomplish this task?
Thanks for your time.
17
reflected vertically even looks likeTL
) \$\endgroup\$
