I am using a bus to connect a repeating module to an MCU in Altium. I've tried numerous variations and can't find an example the same as this. I'm not sure which should have labels and which shouldn't or if they can be the same name.
What is the correct way to do this?
The actual circuit has many other connections but I have simplified the circuit down to figure out the problem.
Sheet Hierarchy:
MCU: (Don't mind mess, just there to suppress driving force errors)
Module:
Edit:
I made a mistake when creating the example circuit which @Daniel pointed out. I fixed the mistake but the original naming problem still exists.
Old errors and top sheet:
