I have a device which needs to connect to one of three devices using ethernet. When one device is connected, the other 2 will be powered down. Power consumption is a factor, so I'd like to use a passive component
Using a RJ45 splitter has failed, I was wondering if anyone has a suggestion for this architecture
Would a single ethernet cable with 4 end terminations work? Is there anything off the shelf for this situation?
Best regards
