I'm trying to calculate the internal resistance of my rechargeable batteries and haven't got a single battery holder so using I am having to using Banana plugs and Crocodile clips for holding my resistor. Then holding the banana clip on the negative end of my battery and reading the current. But could this be affecting my readings as I've tried different resistors and I'm still out in my calculation first time i got ~1000(with a 10k load) ohm now down to 10 ohm(with 68 ohm load). I have even smaller loads to test with now 1 ohm and 0.1 ohm. But this just popped in to my head as it might be problem. The leads I'm using are what we normally use for connecting our PCBs to the PSU, this is why I thought it could be ignored but maybe not when trying to calculate some thing very accurately.
1\$\begingroup\$ Read into 4-wire measurement. There are 2 pairs of wires of which one does the measurement, and the other wires are for the measurement (voltage). Wire resistance on thin wires can become significant in 100 ohm range, of thicker wire at several ohm's. \$\endgroup\$– HansJan 16, 2011 at 16:20
\$\begingroup\$ possible duplicate of Resistance Measurement \$\endgroup\$– tybluJan 16, 2011 at 16:25
\$\begingroup\$ Its borderline duplicate as I'm asking about whether or not I should ignore the resistance of the wires when taking my readings. But your answer is very good. \$\endgroup\$– DeanJan 16, 2011 at 16:34
\$\begingroup\$ I agree: it is borderline, and I like it. I'll try to answer later. \$\endgroup\$– tybluJan 16, 2011 at 16:40
Add a comment
1 Answer
No, it cannot be ignored.
The internal resistance of Lithium ion/NiMh batteries is comparable to one of the wires. Also you should keep in mind that a significant part of the resistance is in the connections to the battery.
So, for precise measurement, you can go for 4-wire measurement, or accurately measure the resistance of the wires and connections, and subtract it.
\$\begingroup\$ Im using NiMH batteries. So will take this in to consideration now. \$\endgroup\$– DeanJan 16, 2011 at 21:41
