A better way than using std_logic_vector and the non-standard std_logic_arith
and std_logic_signed
libraries is to use IEEE.numeric_std.all;
and make the counter unsigned
(or signed in other contexts where you need negative values).
signal hcount : unsigned(7 downto 0);
And you can perform conversions to and from integer, and bitwise operations:
hcount <= to_unsigned(123,hcount'length);
signal somereg : std_logic_vector(7 downto 0);
somereg(to_integer(hcount(2 downto 0)) <= <a bit value>;
However in the given example, the bitwise operations turn out to be unnecessary: instead of masking bits to extract a 3-bit register address, you could use division and mod operations. Synthesis tools (mostly) aren't stupid : divide and mod by powers of 2 are optimised into the obvious field extractions and don't even generate "and" gates.
signal hcount : natural range 0 to 235;
signal reg_addr : natural range 0 to 7;
reg_addr <= hcount mod 8;
somereg(reg_addr) <= <a bit value>;
One benefit of this (apart from fewer ugly type conversions) is that you still profit from the integer subtype you declared for hcount
: incrementing it to 236 will raise an overflow error in simulation, allowing you to catch and correct logic errors early.
