Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I'm familiar with using CMOS switches ("transmission gates") for switching analog signals, but you can't use them for switching voltages beyond their supply rails. (So if you have a single supply circuit, and a voltage signal that's been AC-coupled and to a ground reference, you cannot use a CMOS switch because the voltage of the signal drops below ground, which is the negative supply for the switch.)
However, there are some analog switches that will switch ±25 V signals with a power supply of 0 V and +3.3 V. How do they work? Is it simple to build a circuit like this out of discrete parts?
share|improve this question
up vote 7 down vote accepted
How do they work?
They have integrated charge pumps to create internal supply voltages that are greater than ±25 V.
Possible? Yes. Simple? Not particularly.
share|improve this answer
Would it be worth mentioning that the elevated supply rails don't need to source or sink any significant amount of current and, as a consequence, the charge pumps can be very small? – supercat Feb 20 '14 at 16:15
Making the circuit out of discrete parts gets complicated, but a charge pump can be two diodes, two caps, and a square wave from a microcontroller. Integrated standalone charge pumps are also available, if the beyond-the-rails parts don't meet OP's specification. – markrages Feb 20 '14 at 20:47
Wouldn't this produce at least small amounts of switching noise? – endolith Feb 20 '14 at 20:51
All charge pumps make switching noise. If you roll your own you can set the frequency or filter it or postregulate it. Certainly switching noise is a design consideration. – markrages Feb 20 '14 at 20:57
Some, not all, of those chips seem very explicit on the charge pump properties and what start-up and noise considerations are involved. – Spehro Pefhany Feb 20 '14 at 21:15
discard
