Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I need PWM pulses of 3.3V, and my micro-controller is giving 1.8V PWM signals. I have a voltage source of 3.3V. One way I am thinking is to use two cascaded inverters(like NOT-GATE) using MOSFETs. Is there any other good ways to do this?
share|improve this question
You could use a single MOSFET or BJT. – David Schwartz Feb 26 '14 at 10:32
How would I do with one? – noufal Feb 26 '14 at 10:36
You can often invert the PWM polarity in the microcontroller and use a single inverter (or transistor in common-emitter mode) for level shift. – Brian Drummond Feb 26 '14 at 13:11
Logic level converter: -
This one works with two Vcc levels from 0.8V to 3.6V.
share|improve this answer
You can also use a bi-directional voltage-level translation device. Here are some from ti, analog and maxim.
discard
