Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
A test circuit requires to generate 1V (50Hz, sine) using a voltage divider made of capacitors. Simulation of the circuit using two identical ceramics capacitors (±5%) gives half of the input voltage as output, as expected. But on breadboard using signal generator, two identical capacitors, and picoscope, I get very small (less than 100mV) output. Any idea about this? Here is the test circuit:
share|improve this question
up vote 9 down vote accepted
The reason is that a capacitive divider only works for AC. Another way to look at this is that its output impedance is inversely proportional to frequency, so is very high at low frequencies and infinite at DC.
Your combination of small capacitors and low frequency means the outut impedance of this divider will be quite high, about 16 MΩ in your case. That means even a 10x (10 MΩ) scope probe will attenuate the signal significantly. If you changed the capacitors to 100 nF, then the output impedance will be about 16 kΩ and you should see close to half the input sine amplitude on the scope. However, you still won't see 1/2 the DC level since the DC component of the input will always be blocked.
share|improve this answer
discard
