Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I want to make a USB Y connector from a PC USB backplate it is faster than buying one, fun and educational, (a usb hub is 20 dollars here).
I have many PC USB backplates available to wire into a hub so i had a go:
I wired all the wires of the same color together in Y formation, but i can only use one of the usb plugs at a time, and not both.
Is there a way to switch round some of the colors so that they are useable concurrently?
I thought USB was simply in series / in parallel.
share|improve this question
green and white are upflow and downflow of data. – user4606 Mar 11 '14 at 13:26
@user4606, no they are not. They are a (mostly) differential signaling pair. You might be thinking of asynchronous serial ports. – markrages Mar 11 '14 at 15:00
up vote 10 down vote accepted
USB is not simply in series or parallel.
You need a USB Hub chip to build what you are trying to build.
Good luck!
share|improve this answer
As @markrages noted, you cannot "Y" a USB connection. It simply won't work.
What you are seeing on pre-built backplates with two USB sockets is that the other end is connecting to two different USB ports on the motherboard, combined into a two-wide connector.
To see what I'm saying, please look at figure 6 of this page.
discard
