Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I have 0-5 V analog value coming in, and I need to convert it to a high or low 5V digital signal. Essentially, I need to create a 1-channel A/D converter. The idea is that when my analog voltage goes above a certain threshold, it will set the digital output high, and vice-versa. I saw something about being able to do this with op-amps, but I don't remember where I saw it. I also want to do this without using a microcontroller. Any ideas?
share|improve this question
perfect job for a comparator – m.Alin Mar 14 '14 at 14:39
Are you just requiring one-bit resolution i.e. the analogue signal is above or below a certain threshold voltage? – Andy aka Mar 14 '14 at 16:17
Yes, @Andyaka, that's all I need – crocboy Mar 14 '14 at 16:19
Then you have an answer but think about how much hysteresis you need as shown in the answer. – Andy aka Mar 14 '14 at 16:23
up vote 4 down vote accepted
Typically you'd use a comparator for this. Or you could make a transistor version with a long-tailed pair.
A Schmitt-trigger would be a nice solution for a 0 to 5V input:
enter image description here (Source)
But you pointed to an op-amp circuit...
Here's the idea. An opamp as a comparator with logic output.
It's worth reading through ADI's application note on that (source for the picture).
Their Conclusion is accurate in my opinion and worth bearing in mind:
"In conclusion, although op amps are not designed to be used as comparators, there are, nevertheless, many applications where the use of an op amp as a comparator is a proper engineering decision. It is important to make an educated decision to ensure that the op amp chosen performs as expected"
share|improve this answer
Thank you so much! – crocboy Mar 14 '14 at 16:18
discard
