Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
When bit-banging I2C using 2 PIO lines do these lines still need to be pulled high? Obviously using a dedicated I2C bus the lines must be pulled high as the pins are open-drain outputs but PIO pins aren't open-drain.
share|improve this question
up vote 3 down vote accepted
Yes, both lines need to be pulled high at all time.
Also, when bitbanging I2C, rather than switching the LOW/HIGH states of the pin, switch between LOW/HiZ by simply altering the DDR/DIR registers.
share|improve this answer
The data pin needs to be pulled high, but not necessarily the clock. – Erik Friesen Mar 19 '14 at 10:19
Why is that? Well, I guess, if you only have one master, don't account for slave-induced clock stretching, etc. – Dzarda Mar 19 '14 at 10:24
Why switching between LOW/HiZ is rather than switching between LOW/HIGH states of the pin? – Akshara Prasad Jun 7 '15 at 3:56
As this isn't an answer, it should probably be posed as its own question, or a comment on Dzarda's answer. But anyway, High-Z is used because I2C is a multi-device bus and is designed so that devices are only allowed to drive low, and then an external resistor pulls the line high - this means if one device is trying to output a 1 while another is driving a 0, then they don't short each other out - because the device trying to output a 1 is in High-Z and a resistor is pulling up for it. – Tom Carpenter Jun 7 '15 at 4:07
@TomCarpenter: For the case of a single master driving SPI devices that do not use clock stretching, using an actively driven clock is fine, provided that the time required for the passive pull-up on SDA to generate a rising edge is shorter than the minimum delay between releasing SDA and driving SCK high. – supercat May 25 at 18:45
discard
