Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Simple NPN switching circuit to open a relay circuit, first NPN switching part didn't want to work (3rd PCB and endless times of trying).
Circuit wizard diagrams, I split its first part to figure out the problem, then removed the push button to ease it even more:
(Note top view of components below has been photographically mirrored)
Solution by @ Andy aka: I had short circuit at all resistances.
share|improve this question
Does your regulator heat up when the relay is not energized? A regulator like that is simply a controlled power resistor, so if the relay draws moderate current dropping that current through a resistor from 9v to 5v will produce substantial heat. You can add a heatsink to the regulator package (it is designed with that in mind) but it would be better to use a battery voltage appropriate to the relay and skip the regulator. Also, a 9v "transistor" battery is a poor choice for this, as it will have a short lifetime. – Chris Stratton Mar 21 '14 at 14:31
The fuzzy photos don't help. Are your schematics correct, and which one did you actually construct? Is the relay part of the circuit when the regulator overheats? – Joe Hass Mar 21 '14 at 14:33
Additionally, that regulator requires a small capacitor across its output, and possibly across its input as well, in order to function properly. Leaving that out can lead to instability, or even outright wrong voltage. – Chris Stratton Mar 21 '14 at 14:33
Also, you should put a diode across the relay coil, reverse polarity of the LED. My guess it it's simply heating up because you have a low resistance relay coil. What is that resistance? – Spehro Pefhany Mar 21 '14 at 14:46
It's probably the photo but the tracks don't look like they're cut beneath the resistors. – Andy aka Mar 21 '14 at 15:04
up vote 16 down vote accepted
Shouldn't the tracks be cut under the resistors: -
I've put a label on the picture but the track doesn't seem to be cut anywhere. Maybe it's my eyes?
share|improve this answer
no it's one long tracks along the pcb – AndrewxXx Mar 21 '14 at 16:00
8
Then the copper tracks are shorting out the resistors dude. You need to cut tracks beneath resistors that have both pins on one track. – Andy aka Mar 21 '14 at 16:08
7
@AndrewxXx: He isn't saying "shouldn't it have come from the factory cut already?", he's saying "why haven't you cut the tracks so that the board matches the schematic?". – Ignacio Vazquez-Abrams Mar 21 '14 at 16:24
@AndrewxXx If you want to avoid cutting tracks then you can place the components vertically, from one strip(track) to the other and each track represent a node. – alexan_e Mar 21 '14 at 16:33
Sometimes the most obvious stuff is the hardest to see. – gsills Mar 21 '14 at 16:51
Regulator looks mirrored on the photo.
That looks like a good observation to me +1 – Andy aka Mar 21 '14 at 15:02
i did try to reverse it even that i know it should be like this from the data sheet but ill try to reverse it again, here is how it is now resistorworld.com.au/image/cache/data/4e73_1-500x500.jpg and it output 300 hfe like in the datasheet on the avo, but ill try that "again" – AndrewxXx Mar 21 '14 at 15:02
That is a transistor... Not the regulator – Dejvid_no1 Mar 21 '14 at 15:04
There you go: www.fairchildsemi.com/ds/LM/LM7805.pdf‎ – Dejvid_no1 Mar 21 '14 at 15:05
But the text looks mirrored on the photo, too. In the original picture i.stack.imgur.com/i5412.jpg neither the regulator nor the text was mirrored. So I don't think this is it. – Chris Stratton Mar 21 '14 at 15:15
discard
