Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I want to put relay SPDT in the output of the below circuit to connect with circuit working in 12v.
when the buzzer run the relay switch on or off to another circuit automatically
I want to run it in mulitsim also if some one can explain in details the circuit how it is working and the use of each components I the circuit
share|improve this question
This (original source is here) with some "explanation".
This is a pretty dubious circuit in general and I really doubt an ordinary non-differental photo interruptor will work satisfactorily as a smoke detector at non-lethal smoke densities. If you crank P2 down all the way it will burn out T2. It depends on leakage to keep T4 off. There are other issues.
Modern smoke detectors usually use a sensitive ionization chamber with a tiny bit of Americium-241 radioactive material. Ones that operate photoelectrically usually use a scattering principle. The method suggested here (beam detection) is prone to all sorts of problems.
If you want to use it as a beam break detector, you could try connecting another MOSFET gate to the one driving the buzzer and using that to switch a relay (diode across the coil). But I'd suggest staying away.. this is strictly amateur hour stuff.
share|improve this answer
discard
