Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
After purchasing a TC205 sponge and comparing it with the default sponge that came with my soldering station, I noticed that the TC205 sponge is very thin in comparison!
Is the thin sponge used for a different application? What are the slits on the sponges for?
share|improve this question
21
Did you try adding water to it? – AndrejaKo Mar 29 '14 at 20:12
I know it's not funny to some, but I really can't help laughing a little. I'm old enough that when I was trained they didn't have these tightly compressed sponges. So my first mailed sponge caused me a moment's thought, too. But it only took a second's thought to figure it out. Anyway, to me this is a keeper just for the grins. – jonk Mar 29 '14 at 21:55
9
OMG haha!!!!!!!! – Nyxynyx Mar 29 '14 at 22:17
Question of the month :) – Rev1.0 Apr 2 '14 at 8:47
The sponge comes thin as purchased because the cells have been flattened, but once it is wet the cells relax and the sponge will take its final form. There is no difference between thicknesses of sponge as all they are doing is abrading off the solder without damaging the tip. The grooves provide a larger abrasion surface without increasing the volume of the sponge.
share|improve this answer
Brass wool works a lot better than sponges imo, and doesn't require water.
Not an answer to the question but I agree totally. Hence +1 – Wouter van Ooijen Mar 29 '14 at 21:51
I was thinking that as I typed it, but I decided it was relevant. – markt Mar 29 '14 at 21:54
I personally prefer sponges much more then brass wool. To each their own. – Connor Wolf Apr 2 '14 at 8:44
I tried brass wool for the first time yesterday, and it sure works, BUT it spreads tiny droplets of solder all over the place! I might have had an excessive amount of solder on the iron, but still... – sandos Mar 8 at 13:30
Try pouring water on it and watch the magic of science LOL.
Seriously it should just expand outwards every which way and look just like (or similar to) the one on the right.
Hey I could be wrong but one I did recently expanded beautifully.
Others have already noted that you just need to add water to expand your new sponge. I wanted to address your second question about the slits. Line them up parallel with the iron when you put the sponge in its tray. Then when you drag the iron tip through the sponge to clean it, it can do a better job cleaning the sides of the tip. Some model sponges have the slits, others don't. I've never found it to make much difference either way.
Brass wool is a correct accessories for cleaning soldering iron. Wet sponges should not be used due to worn out of soldering iron due to temperature difference between iron and wet sponge. Soldering iron will degrade faster while using wet sponges. So it is very clerar whether it is thick or thin, sponges should not be used.
discard
