Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I've looked around this site but I haven't been able to figure out why this oscilloscope seems to have such a high sampling rate "Repetitive mode: 20GSa/S" and be relatively cheap: http://shop1.usbdso.com/MSO-9201-with-Logic-Analyzer-MSO-9201wla.htm
Can someone explain?
Thanks
share|improve this question
up vote 6 down vote accepted
This is for a repetitive signal like a standing sine wave.
When I buy a scope I always look for is the real-time sample rate which indicates the maximum rate an incoming signal can be acquired in a single-shot acquisition. On the other hand, repetitive sample is a method of reconstructing a signal based on a series of triggered waveforms that are each acquired in single-shot mode. The advantage of repetitive mode is that it offers a higher effective sample rate. The downside, however, is that it takes more time and is applicable only for repetitive signals. This scope has a real time rate of only 200MSa/s - far from the 20GSa/s.
In general I hate using PC based oscilloscopes and would tell you to go for something like this instead if you're in the market for a scope to use. Unless you are really strapped for money and need the 200MHz bandwidth or really need the deep sample rate.
share|improve this answer
Also called equivalent-time sampling. – user36129 Mar 31 '14 at 9:15
Hi Gonzik, what does the equivalent sample rate mean in the following link? rigolna.com/products/digital-oscilloscopes/ds1000e – david Mar 31 '14 at 21:19
Equivalent-time and repetitive sample are the same thing as pointed out by user36129 above. – Gonzik Apr 1 '14 at 4:00
Short version: Lies from the marketing department. – John U Apr 1 '14 at 7:39
Ok now, I get user36129. Thanks everyone for your help! – david Apr 1 '14 at 13:08
discard
