Inspired by projects such as the tweeting cat door and CATaLOG [sic] I’m wanting to add some form of automated access control to our pet door to control who can go in and out, when.
(Full Disclosure: This is a reprint from my blog where I first wrote up the problem, but all feedback is welcome!)
The Players
We currently have three cats, one dog and one pet door.
The Mischievous Mutt
Toby
Toby, our two year old Labrador needs access to the backyard anytime, day or night for access to his food, water and other amenities.
The Clutter Kittens
Bazyl Kismet
Bazyl and Kismet, are free to go out during the day (sometimes even encouraged) however in an ideal world the pet door would only allow them to come in, but not out again after dark.
The Wanderer
Murray
UPDATE 2010/01/17: Unfortunately, Murray is no longer with us. Old age finally caught up with him.
Murray, the venerable 17 year old veteran of the family who has a habit of going walkabout. At this stage in his life, it would be best if he stayed indoors.
The Portcullis
Pet Door Outside View
Our pet door, that allows the rabble to go out on the deck and into the backyard. The door is fixed in a wooden panel in the frame of what was originally a window.
Requirements Summary
So basically we need something that is able to stop the door swinging outwards during the evening, except when Toby is in proximity, and any time Murray is in proximity. We don't need to worry about foreign cats coming into the house (you've met Toby, yes?) and if we really want to lock the dog out we put the barricade in place as shown below. (We soon learnt that the little plastic lock on the door is not gonna stop him if he really wants in!)
Pet Door Inside View
I'm planning on using an Arduino board as the control unit, and think I need twoone RFID tags – one for Toby and one for Murray – at the minimum to handle the rules I've outlined above.
So the preliminary parts list is:
  • One Arduino controller board.
  • One light sensor for sensing daylight hours.
  • One RFID scanner.
  • Two RFID tags that can be attached to the animals' collar.
  • One solenoid or something else that can be used to stop the flap opening to the outside.
  • A red/green LED to indicate if the door is currently locked or not.
  • A three state switch to enable us to set the door to always open, always locked, or on automatic as required, although we expect it to be on automatic most of the time.
The concerns I have are finding the right RFID scanner and tags that'll work in this environment. I've no experience with RFID but hear a bit about range issues. One tag will be on the collar of a big Labrador, the other on a medium sized cat, so there is a reasonable height difference. The proximity sensing cannot be flaky for this to work, especially for Toby who will get confused if the door only works some of the time and just not bother.
I have been considering an ID-12 or ID-2 scanner with a custom antenna, but people I've talked to think the range will be too small. The size difference between a domestic cat and a Labrador is fairly significant in this case.
Another option might be bluetooth. This would also have the advantage that it could act as a true proximity sensor, detecting when the animal comes into range, remains in range, and goes out of range, whereas RFID is generally triggered once each time the tag comes into range after not being in range. The disadvantage is batteries.
Any other ideas for proximity sensors?
The other thing is the mechanism to block the door. Ideally something that can shoot out out a little bolt to block the path of the door, or retract it to leave the door clear to open. Preferably not something that is spring loaded that needs an active voltage on it to either hold it open or hold it closed. Should only need to apply voltage to change state, not maintain state.
If a bolt is not available, I've seen a stepper motor with a bit of metal on the spindle used to do the same thing. To lock it simply rotates the bit of metal into place, to unlock is rotates it out the way.
So, any and all feedback on the above would be welcome.
UPDATE 2010/01/17: Have finally ordered most of the parts I need for this, as well as the hermit crab tank humidity control, which I'll probably build first ('cause it's simpler). I went with an ID-20 RFID scanner to start with, so we'll see how that goes. Unfortunately, my copy of Practical Arduino which I'll be using as a reference apparently wont arrive until mid-Feb so progress will be slow before then.
link|improve this question
feedback
I am be very interested to see how this works out.
I am currently making an RFID controlled lock for a door and I know from my work on that,that RFID have range limitations(depending on what type of reader and chip you use) so the position of both reader and chip may be very important especially because you're planning on using it on an unpredictable living thing. That might be a big challenge and may require more than one RFID reader.
As far as a locking mechanism you can make one really cheap by taking apart an old cd drive and using the slots drive system.
link|improve this answer
That's a pretty good idea, using and old CD drive. I think I have one or two of those laying around! – Evan Nov 2 '09 at 0:46
Not the first time a CD drive has been used as part of an access control system either, now that I think of it! thedailywtf.com/Articles/Open-Sesame.aspx – Evan Nov 2 '09 at 4:51
ya CD drives are really useful and easy to use all you need is a motor driver. Its a great way to get linear motion without building a gear system or by a linear actuator. – zklapow Nov 2 '09 at 5:14
Also you said something about and ID-2 with a custom antenna. Im using an id-12 and its range is only about 4 inches, but what if you used an ID-2 and ran its antenna around the outer perimeter of the door? That way as the animals will pass right through the antennae. – zklapow Nov 2 '09 at 5:20
feedback
I can't really help you with the issue of identifying you pets but for the latching mechanism you should look into linear actuators. The friction in the ball/screw drive of the actuator will be enough to hold the lock in place without applying power to the motor. A simple DC actuator (with built in limit switches) and a throw of 1cm-2cm should be enough to operate a set of bolts. Linear actuators are typically slower than servos and solenoids but have more power and will stall the mechanism without using power.
That sounds like it could be exactly what I'm after for the locking mechanism, thanks! – Evan Nov 2 '09 at 0:45
feedback
At Uni I did a talk on RFID chips as part of one module for my course. Based on the research I did then, and never actually having used them in real life, you probably will need to research/play with different chips to find ones that work. some chips can be blocked by a bottle of water, so whether a dog or cat's neck will do the same thing depends.
Possible problems that spring to mind:
Does the position of the chip on the collar (top, bottom, side etc) relative to the sensor(s?) have an effect on detection?
Will you need more than 1 sensor?
What happens if your dog is in proximity to the flap, when the older cat wants to get out? Are you thinking that the chips will only be on cats which are not allowed out, thereby locking the flap whilst in proximity?
If there are commercially available versions of this technology, see if you can find out what they use, including which brand/type of chip.
A book which was particularly useful whilst researching RFID as a topic (it seemed to have lots of case studies of implementations in it too) was RFID for Dummies which is here on Amazon in the UK.
(That pretty much exhausts my knowledge of RFID, let us know how you get on, somehow.)
Cheers Amos
feedback
ZigBee could be a decent alternative for RFID. I've never used it, but it's designed for situations like yours.
Not sure how ZigBee would work for this. Looking at en.wikipedia.org/wiki/ZigBee the range is 10m or more, which is probably a bit far away (really want a range more in the 1m mark), unless ZigBee transmitters can detect their range from each other? – Evan Nov 3 '09 at 22:50
feedback
i'm working on something like this myself. i have an id-12 in hand that does not seem to read my cat's tag. i have a couple of other rfid tags on hand that it will not read, and one that it can read from 6" away (no antenna on everything).
i'm not certain of the khz of the tag in my cat, or any of my others except for the "control" card i bought with the reader for testing.
the id12 is the easiest thing in the world to use in ASCII mode, and this is all ive tried. i think i might have to find a 134khz model and or a proper antenna to get any farther.
feel free to contact me. turbohoje@h0tmail
Hi, Justin. If by the "cat's tag" you mean the one inserted under the skin by the vet, no reader is going to be able to read it at a range of more than a couple of centimetres. They're purely for identification and not designed for proximity detection at all. Most existing cat doors I've seen that use this chip involve a tunnel that forces the cat to come close enough to the sensor. No good for my various sized animals. – Evan Jan 17 '10 at 9:50
feedback
To read EM4100 tags (the cheap, 125 kHz kind) you need to get a good coupling between the tags coil and the reader coil.
The bigger the tag coil, the better and more reliable the signal will be.
First of all you'd need to wrap the reader coil all the way around the portal to ensure that the animal is going to be within the magnetic field.
Second of all you need to make sure that the tag coil is parallel to the reader coil, I think the easiest way to do that is to build collar where the coil is built into the collar and connected via a connector where the chip is located.
The entire trick is to build the RFID collar to be both durable and removable.
The circuit for the reader is very simple and can be built for under $2 provided you have an AVR such as the one found in an Arduino to connect it to, take a look at the bottom of this schematic: http://www.hackaarhus.dk/forum/download/file.php?id=33
feedback
I can't help with the RFID portion, but to lock the door you can purchase surplus car lock actuators, they are simple solenoids that works off of 12Vdc. I have not used them yet but I plan on using them for a locking chest.
That's a great idea, thanks! – Evan Dec 3 '10 at 23:53
feedback
Have also done some work with RFID and Arduino if anyone is interested.
feedback
or
required, but never shown
