Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Does a MOSFET allow current flow in reverse direction (i.e.; from source to drain)?
I made a Google search, but couldn't find a clear statement about this matter. I have found this similar question, but it is about detecting current direction from the schematic symbol of a MOSFET. And under the same question, there is this answer which states that MOSFETs have no intrinsic polarity, thus they can conduct in both directions. However, that answer has no up/down votes or comments, so I can't make sure of it.
I need a clear answer on this. Does a MOSFET conduct in both directions?
share|improve this question
Following this circut. I dont see the ac's direction to return itself. – user63837 Jan 7 '15 at 6:29
up vote 11 down vote accepted
Yes it does conduct in either direction.
Due to the body diode, most discrete MOSFETs cannot block in the reverse direction, but the channel will conduct in either direction when the gate is biased "on".
If you want to conduct and block in both directions you need two MOSFETs in series.
MOSFETs used as near-perfect rectifiers are usually used in the reverse direction for conduction (so they can block in the other direction).
Edit: Your schematic here: enter image description here
Illustrates one example of switching AC with two MOSFETs (one of which will be conducting in reverse at any given time when the switches are on).
Another example is here, from the LT4351 datasheet:
share|improve this answer
Using two MOSFETs like this? You can attach this image to your answer if it is correct. – hkBattousai Apr 6 '14 at 9:48
Yes, that's right. Effectively back-to-back. They're easier to drive if the common can be grounded as you've shown. See the LT4351 datasheet for another example. – Spehro Pefhany Apr 6 '14 at 9:53
discard
