Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I'm using a SparkFun-built Arduino Pro Mini 3.3V / 8MHz. One thing I need it to do is toggle the gate pin on a MOSFET, and that's not working for some reason. Getting in there with a multimeter, I see that the voltage on the pin never goes HIGH. The only thing I have running on there is the following bit of code:
void setup()  {
  pinMode(A7, OUTPUT);
void loop() {
  digitalWrite(A7, HIGH);
Any thoughts on either configuration or electronics that could be causing this?
The pertinent part of the schematic is:
share|improve this question
From the schematic, it appears that both A6 and A7 are used in a similar way. Does the A6 pin work if wired to the RUD_EN connection (and vice versa)? Do you have a replacement Arduino Mini to test with, the processor or board connection may be bad? – Ron J. Apr 7 '14 at 13:41
No, they're behaving the same way. I did test with another one - no go. It's definitely either a wiring issue or a code issue, not something with the board – kolosy Apr 7 '14 at 13:44
up vote 5 down vote accepted
A6 and A7 are Analog Input Only. This is most likely what your are running into.
The TQFP package of the AtMega328 has 2 more inputs that the DIP package (A6 and A7), but they are analog input only. 1.1.9 in the datasheet.
share|improve this answer
sigh yes - it's looking that way. – kolosy Apr 7 '14 at 13:44
@kolosy - If you could see fit to add a small I<sup>2</sup>C parallel port expander to your design your could take the two wire port of the MCU and get support for 8 I/O pins at the expense of only two on the MCU. At least the port expander could be used to drive RUD_EN and WINCH_EN and monitor RUD_V and WIN_V. – Michael Karas Apr 7 '14 at 14:39
I'll look into that, thanks. I think for the time being, I just need to move some things around, still have enough GPIOs. – kolosy Apr 7 '14 at 14:51
discard
