Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
The other day I received a promotional wrist band from a convention booth -- it has two LEDs that flash when you jostle it. I removed the guts to see how it works, and here is what I found:
photo of device in clear shell, with PCB and components visible, 45mm x 15mm
Most of this is pretty straight-forward: LEDs, a SOT-23 transistor, some passives -- no uC that I can see (on top, at least) -- but I'm interested in the metal can in the middle, with the refdes K1. I assume this is the sensor that detects when the device has been tapped or shaken. It's a metal cylinder with two leads, and on the inside there is a smaller metal cylinder -- it might be a coil or spring, but it's hard to tell. Here's another picture where you can sort of see it:
a more-nearly end-on view of the can device
Does anybody know what this component is called and how it works? Maybe the spring moves when shaken, changing the capacitance or inductance. Whatever it is, it must be cheap (this is a give-away promotional item). It would also be nice, I imagine, if the mechanical energy it collects is enough to wake-up the rest of the device so that it could have a no-power sleep state.
Note, too the shiny metal pad under the near end of the can, perhaps a ground needed for the operation of the device. It looks like there is some clearance between the can and the pad (and the rest of the pcb, for that matter).
UPDATE: Based on the feedback, it's probably a vibration-induced trigger switch, something like this (datasheet), that is, just a spring in a tube that makes contact with the case when it moves.
share|improve this question
up vote 5 down vote accepted
It's just a spring in a tube. The spring is anchored at only one end. When shaken, the other end of the spring touches the tube and completes the circuit.
The transistor functions as a simple amplifier so that the full LED current doesn't need to pass through the sensor.
share|improve this answer
Precisley. I've seen a lot of them around but they were vertically oriented, with a rod in the center of a spring, both soldered on the pcb. – Vladimir Cravero Apr 8 '14 at 16:48
Dave, you must be right. Is there a standard term for these? I spent some time on Digikey searching with variations on 'vibration switch', 'vibration sensor', 'motion sensor', 'spring switch', 'coil switch', etc. but I can't find it. – David Apr 8 '14 at 18:50
It might be something similar to what we use in one of our products (SQ-SEN-200 from SignalQuest). It is omni-directional since it has a gold ball inside of it, which makes/breaks contact between the two leads. It is extremely sensitive, as I can detect someone lightly tapping on the other end of the desk. A spring is only sensitive in two axes, so you might test for that, although it would be difficult.
A spring is sensitive on two axes. It is only insensitive on one axis. – Dave Tweed Apr 8 '14 at 17:56
Ah. Thanks, I misunderstood the construction. I'll correct my answer. – TimH Apr 8 '14 at 18:15
TimH, good idea -- I can confirm it does not respond very well to motion along the axis of the cylinder. – David Apr 8 '14 at 18:43
discard
