Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
For a project I want to have two microcontrollers talk to each other via an SPI interface. I wrote the following code for the slave:
volatile uint8_t data;
void spi_init_slave (void)
 DDRB=(1<<PINB4);               //MISO as OUTPUT
 SPCR=(1<<SPE)|(1<<SPIE);       //Enable SPI && interrupt enable bit
 SPDR=0;
uint8_t SPI_SlaveReceive(void)
  /* Wait for reception complete */
  while (!(SPSR & (1<<SPIF)))   ;
  /* Return data register */
  return    SPDR;
ISR(SPI_STC_vect)
  uint8_t y = SPI_SlaveReceive();
  PORTD = y;
int main(void)
    DDRD = (1<<PIND0) | (1<<PIND1) | (1<<PIND2) | (1<<PIND3) | (1<<PIND4);
    spi_init_slave();                             //Initialize slave SPI
    sei();
    while(1)
The master is sending a number which the slave displays using the LEDs attached to port D. I'm using an Atmega8P for this project.
share|improve this question
Above code is working now, fixed typo. – BoboProg Apr 19 '14 at 11:17
up vote 3 down vote accepted
The most apparent problem I can see is the following line:
SPCR=(1<<SPE)|(1<SPIE);
Is missing a less than sign and should include (1<<SPIE) to enable the SPI interrupt. Note that the current expression (1<SPIE) will be equivalent to the boolean expression (1 < 7) which will result in a value of 1. So that also means at the moment you'll be setting SPR0 for a speed of fosc/16 on the master.
share|improve this answer
You've made my day. Thanks! Only the slave doesn't have to "match" the speed of the master. Quoted atmel datasheep pp 126: "Bits 1, 0 – SPR1, SPR0: SPI Clock Rate Select 1 and 0. These two bits control the SCK rate of the dev ice configured as a Master. SPR1 and SPR0 have no effect on the Slave." – BoboProg Apr 19 '14 at 11:15
Ahh yes good point of course I re-worded that part. – PeterJ Apr 19 '14 at 11:21
I know this is a year old, but I thought I would just point out that when I tried implementing your code, the interrupt routine was only firing every other SPI transfer.
I believe this is because of this line:
when you actually want:
while ((SPSR & (1<<SPIF)))   ;
Hopefully that saves someone else some of the time I spent scratching my head.
discard
