Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I am trying to figure out what is going on here.
I have a simple circuit to send current to a brushless fan running at 12V on the high side, using a NPN transistor 2N2222A:
Schematic
This is the picture of the datasheet for the pins:
Datasheet
If I set up the circuit for a quick test, it seems that the datasheet (or the transistor) has the pins swapped.
When I apply a voltage between the pin 1 to 3, as soon as the voltage rises over about 8V, the current starts to flow, even when the base has no voltage (pulled down or floating), and the transistors gets pretty hot. It looks like a "diode".
If I rotate the transistor 180°, everything works as I would expect, current flows, and the fan power is proportional to the base voltage.
This is the pic of the transistor, as I understand that it should work, but it doesn't (it is always 'on' with 12V between the collector and the emitter with the base floating).
What do you think? Am I missing something here?
share|improve this question
up vote 8 down vote accepted
There really isn't a single '2N2222' transistor, since each manufacturer just seems to use XYZ_2N2222 as a part number for a generic 'NPN silicon amplifier transistor'.
Hence the 2N2222 pin-out is sadly not standardized. Most 2N2222s have the orientation which your diagram shows, where if the flat side is facing you, the pins are E-B-C respectively. However, some manufacturers have the pins going C-B-E for the TO-92 package. For example, the ON Semi P2N2222A variant: datasheet
share|improve this answer
6
With it wired the wrong way round the emitter is more positive than the collector and the base is reverse biased. Absolute maximum rating for emitter-base voltage is 6V hence the E-B junction broke down and started conducting. Would I reuse it? I don't think so - throw it in the bin. – Andy aka May 6 '14 at 16:35
oh my god! this is awful :/ i didn't check other manufacturers – Javier Loureiro May 6 '14 at 19:36
It can be even worse, since the On Semi PN2222 has the conventional pinout, despite being the same manufacturer and mostly same specifications: onsemi.com/pub_link/Collateral/PN2222-D.PDF (note the difference in part number, PN2222 vs P2N2222) – Zuofu May 6 '14 at 23:45
discard
