Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I have a H-bridge based on FAN7392 drivers. This bridge works at 350VDC to output a approximately 240V 50Hz waveform. This circuit is isolated from rest of the board and I would like to maintain the isolation. The bridge is fed by two complementary PWM signals from a microcontroller. The signals can be isolated easily with opto-couplers - however I'm worried that the timing difference between the opto-isolators might cause one side of the bridge to turn on both it's transistors simultaneously, for a short time. For instance, if one opto-coupler takes 2us to go high while the other takes 3us to go low there will be a 1us interval where one half of the bridge will be short-circuiting the power supply.
So my main question is, what is the best way to isolated timing critical signals?
share|improve this question
Also, take a look at this: silabs.com/Support%20Documents/TechnicalDocs/… – Dzarda May 9 '14 at 12:45
up vote 4 down vote accepted
For an application like this I'd consider sending only one PWM signal through one opto and, at the H-bridge side, recover that signal and apply the inversion and necessary timing differences to prevent shoot-through.
Here's a circuit that can avoid shoot thru by introducing a dead-band i.e. no overlap: -
Using a small time constant RC low pass filter and schmitt trigger OR and AND gates you can manufacture two PWM signals from one - all you should need to do is invert the output from the OR gate and you have dual, complementary PWM signals with shoot-thru protection.
share|improve this answer
Won't the additional inverter add another propagation small delay into the signal? – Saad May 9 '14 at 14:07
It probably won't be significant but, if in doubt use an EXOR on both outputs and set one to invert and the other to not-invert – Andy aka May 9 '14 at 14:17
discard
