Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
The way I interpret the resistance \$R\$ of a resistor, which has dimensions \$ [\frac{\mathrm{V}}{\mathrm{A}}] \$ is: how many volts must be applied across the resistor to achieve 1 ampere of current?
The conductance \$G\$, which has dimensions \$ [\frac{\mathrm{A}}{\mathrm{V}}] \$ is then: how many amperes of current flow through the resistor when applying 1 volt?
I realize that these quantities are related to the geometry, whereas the resistivity \$ \rho = R\times \frac{A}{L} \$ which has dimensions \$ [\Omega \cdot \mathrm{m}] \$ is an intrinsic property of the material (doping of semi-conductor, electron/hole mobility, etc).
However, I cannot achieve an intuitive understanding to interpret the dimensions of resistivity. Can this be clarified?
share|improve this question
up vote 8 down vote accepted
\$\Omega\$m is the simplified unit of resistivity. The full unit is \$\Omega \$m\$^2/\$m. This means that a given length of material with a given cross sectional area will have a certain resistance whose value can be calculated using the resistivity.
For a 1 m length of material with a 1 mm\$^2\$ cross sectional area and a resistivity of 1:
\$1 \Omega \mathrm{m} = R(10^{-6}\mathrm{m}^2/1\mathrm{m})\$
\$R = {1\Omega \mathrm{m} \over(10^{-6}\mathrm{m}^2/1\mathrm{m})} = 10^6\Omega\$
share|improve this answer
Maybe it's easier to understand intuitively if you don't reduce the dimensions, in the same way of thinking as the units of gain as volts/volts, you could think of the units of resistivity as \$\frac {\Omega \mathrm{m}^2}{\mathrm{m}}\$, which fits with the physical interpretation of a resistive object of constant cross-sectional area and a given length.
Consider also the usual dimension for sheet resistivity, which is \$\Omega\$ per square, where "per square" really doesn't mean anything dimensionally, but prevents confusion with simply saying \$\Omega\$.
Another example, the units of torque (\$\mathrm{n}\cdot \mathrm{m}\$) are the same as the units of work- it's the physical interpretation that makes the difference.
The simplified unit Ω·m can be interpreted as:
If you multiply it by a length — specifically a thickness — then you obtain the resistance of an arbitrarily-sized square of that material with that thickness.
This is less useful in practical situations than the un-simplified interpretation.
discard
