Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I have a sort-of black box of a circuit that is used to generate plasmas. I'm sure it outputs on the order of kV but I'm not sure at all about the current. I was wondering if there is a way to measure the voltage waveform in consideration of the fact that the oscilloscopes I have available to me are rated for 300V rms. Measuring the current would be great also but not as much of an issue (I'm aware of this answer Measure current in high voltage (10kV) but I don't have the same materials).
Any help is much appreciated.
share|improve this question
up vote 6 down vote accepted
This is not easy to do well, especially safely, especially without excessively loading the circuit, and if you want a decent bandwidth. I have a Fluke High Voltage multimeter probe, but the bandwidth is only 150Hz, so it's useless for anything much above the 3rd harmonic of mains frequency.
A 20MHz Bandwidth 40kV Chinese probe is about $320 (from the usual online sources). This type has a 100M input resistance and an input capacitance of about 1.5pF (designed to work into a 1M scope impedance). There is an adjustment to compensate the probe, just like low voltage probes (but a typical square wave source might be down in the grass of your scope with the gain cranked up all the way).
Internally there are one or more high voltage (fairly) precision resistors paralleled with a similar number of high voltage capacitors and an capacitor and trimmer capacitor across the output, all with enough dielectric and physical size to make arcing-over relatively unlikely.
Here is a video of a dude playing around with one of these to measure flyback voltages and such like, and apparently surviving unscathed.
Of course any probe affects the point being measured, and if the "plasma" thing is a toy plasma globe, it will probably load the source severely since at (say) 40kHz, a 1.5pF capacitor has an impedance of under 3M ohms, which dominates over the 100M resistance. If it's a commercial plasma source for a sputtering chamber, you might have better luck.
Be sure to follow proper safety procedures and verify that all instrumentation meets safety certifications if you're dealing with potentially harmful voltages and currents.
The internal schematic of the probe probably looks much like the below, where the parts have quite unusually high voltage ratings (4kV) and the physical arrangement is also quite important to maintain safe creepage distances and to keep the capacitances similar.
A similarly spec'd Tektronix probe is around $2,000.
Measuring the current would be easier if you did it on the low side (resistor and your 10:1 scope probe).
share|improve this answer
Construct a resistive potential divider that say operates to reduce the input voltage by 1000 to 1. You'll need several resistors to do this of probable value greater than 1Mohm and they'll need to have a voltage rating that is suitable. However, these are more user-friendly: -
These from Vishay are suitable up to 3kV. These will work up to 50kV (different types to choose from). There are a bunch here that look like types I've used before.
If you do consider using several series resistors to build up the potential divider, take extra care with this because any significant capacitance difference between one resistor and the next can cause problems with resistors dying - the one with the least effective parallel capacitance "receives" the transient when applying the high-voltage. This can cause it to breakdown and suddenly the whole bunch can go "pop".
Try to stick with a single high-voltage resistor or preferably a self-contained potential divider like those from Vishay, above.
My answer is basically the same as Andy aka's, except that you use an I/V converter at the low side. You treat the high resistance with a high voltage across it as a current source. You convert that current to a voltage. The advantage is that the output of the high resistance is a virtual ground, so you can protect it easily with two anti-parallel diodes.
discard
