I'm looking to measure distances from a submersed robotics project in the range of 1 to 20 feet (around there at least). However, the only options I seem to come across are rather heavy sonar modules that cost hundreds of dollars. Are there lighter, cheaper alternatives? I don't need great resolution or accuracy, just a decent measurement. Perhaps it's possible to waterproof a normal distance sensor (IR or ultrasonic)?
I intend to interface the sensor with a microcontroller so it would be nice to have something that outputs 0-5 V, but that's not a requirement.
Thanks.
link|improve this question
IR probably will not work very well, water absorbs red light. Ultrasonic sounds good, but i have no idea how well it works underwater. – jsolarski Mar 7 '11 at 7:59
I have a feeling you should be able to waterproof piezo elements rather easily for underwater operation, both as a speaker and a mic. I have never tried through, so don't hook up anything expensive to it if you do ;) – drxzcl Mar 7 '11 at 10:12
feedback
up vote 1 down vote accepted
Ultrasound would be your best shot. A quick search on the web tells me that unless you want do do a significant amount of work yourself it's not going to be cheap. Transducers from Senix cost about $500, but if you can get a hold of a waterproof ultrasound sensor for parking aid systems and is able to build the tx-amplifier, the transmit/receive switch, and do the signal processing in a uC you should be done for a lot less than that.
link|improve this answer
feedback
Fish-finders like this Garmin unit are quite inexpensive at about $100. Buy one of those and use the transducer. You might even be able to buy the transducer quite cheaply as a spare.
...but understand that the transducer will output data which can be turned into something you'd see on a fish finder LCD. It will not be trivial to parse! – Kevin Vermeer Mar 7 '11 at 13:35
The transducer simply emits a pulse and receives the echo. The processing is done by the main unit. – Leon Heller Mar 7 '11 at 13:54
Precisely! But the signal processing required to transform that echo into "the nearest solid object is x feet away" is going to be very difficult. – Kevin Vermeer Mar 7 '11 at 14:29
It just involves measuring the time for the reflected pulse to arrive back at the transducer. – Leon Heller Mar 7 '11 at 14:31
feedback
or
required, but never shown
