Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Say I've got a 5V circuit that draws 30W. 1Ws is a joule, so to run this circuit for 1s I need 30 joules of energy.
The amount of charge stored in a capacitor is \$\frac{1}{2} CV^2\$; solving for \$C\$, I'd need a 2.4 farad capacitor to run my circuit for 1s. That's pretty big.
But say my circuit only drew 30 W at an absolute maximum, and only for very brief periods, like, say 0.25 s at a time. Mostly it was drawing 20 W or so. Which means mostly a 25 W power supply would be plenty enough to drive it. Could I use a \$0.1F (= 2.4 F \times 0.25 s \times 5/30W)\$ capacitor to "take up the slack" of that extra 5 W the power supply isn't rated for?
Have I got the theory right, and would this work in practice?
share|improve this question
To be sure, the joule is a watt-second, not a watt-per-second. – Alfred Centauri May 25 '14 at 11:58
up vote 2 down vote accepted
Your theory is correct, but not complete.
When you start discharging capacitor - voltage will drop. When you draw 50% of energy from capacitor - capacitor voltage will drop by 50% by 30%. With power supply connected in parallel - capacitor voltage will not drop so deep, because current will just start flowing from supply, and you will be unable to get energy from capacitor.
Edit: image removed.
More useful information: link
Many power supplies have rating determined by temperature.
If you have power supply with transformer - you can overload it by 20% with no problems at all if you "let it rest" later.
If you have supply based on voltage converter (transformerless) this is more complicated - you may have problems with voltage stability, voltage drops, temperature etc. In general - you shall not overload transformerless power supply, even for a short time.
And one more thing about big capacitors - they are able to draw very large currents when they are charged. Supercapacitors should be charged from current limiter.
share|improve this answer
If you remove half the energy from a capacitor, the voltage drops to 70% of its original value. If the voltage drops to 50%, you've removed 3/4 of the energy. – Dave Tweed May 25 '14 at 10:32
@DaveTweed you are right. Thanks for pointing that. – Kamil May 25 '14 at 10:33
Ah, I see. In my practical application it's a switching power supply (which is what you mean by "transformerless", yes?.) – Robert Atkins May 25 '14 at 10:40
@RobertAtkins Yes, i mean switching supply. – Kamil May 25 '14 at 10:43
FWIW - iamge page says "From 125 Physics Project for the Evil Genius. Copyright © 2009 by The McGraw-Hill Companies. All Rights Reserved. " – Russell McMahon May 25 '14 at 14:21
protected by Nick Alexeev May 25 '14 at 19:38
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
