Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Currently I am working on an H-Bridge. To drive the MOSFETs on the H-Bridge, I have used PWM signals (5V). Voltage supply at MOSFET is 12V.
When I provide 5V PWM to the gate, the MOSFET heats up but if I provide 12V PWM (implemented by using comparator between controller and MOSFET) to the gate, then there is reduction in losses, MOSFET doesn't heat up too much.
My question then is: Will the reduction of the potencial difference between drain and gate result in reduction of switchihg losses or conduction losses? If so, why?
share|improve this question
Insufficient reading of datasheets. – Ignacio Vazquez-Abrams May 26 '14 at 11:30
up vote 4 down vote accepted
If you look at the on resistance characteristic of an IRFZ44N (for instance) it is like this: -
I've drawn a vertical red line that corresponds to a drain-source voltage of 0.3V and if you look at the horizontal lines I've drawn you should see that for this volt-drop there can be several different values of current thru the drain.
These several different values (ranging from 4.5 amps to 25 amps) correspond to the drive voltage on the gate. So with a 4.5 volts drive voltage on the gate, the on-resistance will be 0.3 volts / 4.5 amps = 67 milli ohms. When the gate voltage is 15 volts, the on-resistance will be 0.3 volts / 25 amps = 12 milli ohms.
Clearly, you can expect that the on resistance will be lower when the gate voltage is higher. When the on-resistance is lower, for a given current, the power loss (\$I^2R\$) will be smaller.
By the way, these above are "conduction losses" and not "switching losses" although switching losses can be improved with higher gate drives (and faster gate drives). Switching losses are when the MOSFET turns from a high-open impedance to a low on-impedance - the in-between period is determined by the speed of the MOSFET's driver - slower speed means the MOSFET spends a longer time at some value of resistance that is neither fully-on or fully-off.
share|improve this answer
discard
