Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Do constant current batteries exist? If not, why not? Else, why are they not very common in the market?
I am not talking about an ideal current source. But it should be a constant current source for few range of values (load, voltage or something). "1mA source with max terminal voltage of 20V" or something like that (I am not sure about the specs).
share|improve this question
up vote 11 down vote accepted
Russell is bang-on for conventional electrochemical batteries, AFAIK, which makes sense because electrochemistry works on voltages.
However, there is something that is considered a battery that inherently produces a constant current. See this presentation.
Betavoltaic cells are based on radioisotope sources such as tritium. There are even some commercial products, though it's not clear from their site what the I-V characteristics are.
share|improve this answer
So a constant current battery do exist and is in its way to market. – nidhin May 26 '14 at 14:20
And it will cost $thousands and only be used in very special applications. – Spehro Pefhany May 26 '14 at 14:26
@nidhin - My 1st summary answer applies - ie "Essentially no". | On its way to market since 1968: 1968-74: Dr. Larry Olsen at Douglas Labs developed the first semi-commercial betavoltaic battery (BetaCel) || Power levels of microwatts. || Left the market: Betavoltaics were invented over 50 years ago. Early pacemakers used betavoltaics based on Promethium,[3] but were phased out as cheaper lithium-ion batteries were developed. || en.wikipedia.org/wiki/Betavoltaics || Available 2012 - 6-8 weeks lead time, 1000's of $. Nanowatts of power - ... – Russell McMahon May 26 '14 at 14:35
... gizmag.com/city-labs-nanotritium-betavoltaic-battery/23720 || Useful - large.stanford.edu/courses/2013/ph241/harrison2 || None on ebay. None on Alibaba - Wow !!! :-) – Russell McMahon May 26 '14 at 14:39
@RussellMcMahon Until at least one of {Amazon, Digikey, Mouser, eBay, Alibaba} have it, it doesn't exist. – Spehro Pefhany May 26 '14 at 14:40
["Battery" used for "cell" in many places below]
Essentially, no.
A battery could easily be made that had that characteristic by adding electronics in the battery housing, and 'for extra points' one could be devised which electrochemically did a good job of current limiting at a designed maximum current, which would then be a constant current battery. But, such devices are rare or nonexistent.
A battery can be made to approximate a constant current source by adding a series resistance - the larger the resistance the better the approximation - and the lower the current. So very discharged batteries, with high internal resistances, are better approximations to constant current sources than fully or partially charged ones.
A photovoltaic cell loaded past its maximum power point also acts as a constant current device. Whether that qualifies as a "battery" is debateable.
Image from Wikipedia - MPPT
V/I characteristics of a "solar cell". Here, for voltages below about 0.35 V, as load increases voltage falls at about constant current. Family of lines shjow output at various light levels.
Batteries are also NOT constant voltage devices (see below)
If not why?
Simple answer: There are much better ways of implementing constant current energy sources when required.
A battery is essentially an energy source with a defined voltage & current profile across its discharge range. With the exception of exceedingly specialist reference cells such as the "Weston Cell" which are designed to be constant voltage sources, batteries are also not constant voltage sources - their voltage decreases with both increasing load and decreasing state of charge. While a battery may be optimised to produce a flatter voltage vs discharge curve the usual major aim in battery design is to optimise some mix of energy density*, power density*, discharge rate, recharge rate, longevity and cost effectiveness.[* both per mass and per volume]. Constancy of discharge voltage is useful but tends to rank below most of these other factors. A lead acid battery is a reasonable approximation to a constant voltage source - but its much preferred LiIon replacement is much less so (4.2 to 3V discharge range or 29% decrease from fully charged).
Constant current energy supply is much less useful and liable to be even less efficient in terms of the usual design parameters mentioned above.
When a constant current source is required it can be implemented electronically in such a way as to optimise some mix of accuracy, energy efficiency and cost as required - and the result will be vastly better than could be achieved electrochemically. This allows the battery design to be optimised for its energy sourcing capabilities.
A constant current source has, by definition, a high open circuit voltage and operates at little or no output voltage if required when loaded heavily. The energy efficiency of an electrochemical product with this characteristic would be abysmal at low load resistances as the majority of the energy produced would need to be dissipated within the battery. The only alternative would be to in some way reduce the electro-potential of the "driving reactions" as load current exceeded the design current. Alchemists may have been able to achieve this but modern science may be challenged.
Related:
Constant voltage cells:
Wikipedia - Weston Cell
Ugly truck
  • Weston cell - constant voltage reference: The original design was a saturated cadmium cell producing a convenient 1.018638 Volt reference and had the advantage of having a lower temperature coefficient than the previously used Clark cell. The temperature coefficient can be reduced by shifting to an unsaturated design, the predominant type today. However, an unsaturated cell's output decreases by some 80 microvolts per year, which is compensated by periodic calibration against a saturated cell.
Wikipedia - Clark Cell
  • The Clark cell, invented by English engineer Josiah Latimer Clark in 1873, is a wet-chemical cell (colloquially: battery) that produces a highly stable voltage. In 1893, the output of the Clark cell at 15 C was defined by the International Electrical Congress as 1.434 volts, and this definition became law in the United States in 1894. This definition was later supplanted by one based on the Weston cell.1
Although batteries are certainly not ideal voltage sources, they are equally certain better at being a sort-of constant-voltage source than at being a sort-of constant-current source! – Wouter van Ooijen May 26 '14 at 13:50
thanks for the answer. Since it is a basic circuit element, somebody would have tried to make one. Any info?? – nidhin May 26 '14 at 14:24
@nidhin - There is no try, only do - see above answer. Re "any info?" - see above answer. – Russell McMahon May 26 '14 at 14:49
@RussellMcMahon I see that. but I was looking for attempts from alchemists. – nidhin May 26 '14 at 15:16
@nidhin If you want attempts from alchemists, direct your question to skeptics.stackexchange.com, perhaps such a battery was found in Roswell. – Joe Hass May 27 '14 at 13:57
Maybe this is cheating, but any battery with a very high internal resistance connected to a load with a proportionately lower resistance is a good constant current source. The schematic illustrates a somewhat extreme example:
Schematic of a simple constant current source
The current is primarily limited by the 9.9M series resistance and changes in load resistance have little effect. Even if the load includes voltage sources less than 10V the current is constant within 1%.
Batteries are normally pretty good voltage sources because their internal resistance is designed to be quite low. Their output will decline with charge delivered but the low internal resistance doesn't result in much variation in output voltage with load resistance as long the load resistance is large compared to the internal resistance.
A much simpler and pretty accurate constant current source may be made from an instrumentation amplifier with a resistor in series with the output and the far side tied to the REF input. The amplifier will try to maintain a constant voltage across the resistance, resulting in a constant current through it that can be directed to the load
Even though its cheating, what you are saying is a solution to implement one. And I think Russel has mentioned this point in his answer. – nidhin May 30 '14 at 13:13
discard
