Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I frequently meet the references to voltage-regulators and voltage-controllers. However, looking at the specs I find them to perform the same function. Is there a difference between the two, or regulator/controller can be interchanged?
share|improve this question
Please provide a few particular references (links), which you've come across. Without that, the question is a bit broad and unclear. In practice, "voltage controller" can mean different things in different context. – Nick Alexeev May 27 '14 at 17:47
up vote 5 down vote accepted
A voltage regulator produces a stable output voltage that has small variance over a range of load and input conditions.
A controller is a device that monitors and modifies the state of a dynamical system. A voltage controller could be constructed to track a signal, minimize undesired signal characteristics, or even act as a voltage regulator.
share|improve this answer
In the context of electronics: A complete regulator requires a controller. The figure below shows the block diagram for a simple voltage regulator. Here, the "controller" includes a series power component.
Control reg
discard
