Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I want to drive around 80 LEDs from an Arduino with 10 8-bit shift registers. (Some will be RGB LEDs; I count those as 3.) I know of the TPIC6B595 high power shift register but it's expensive: 1.75 USD from DigiKey and Mouser. I would prefer to do this cheaper.
I can get 74HC595 low power shift registers for 50 cents and ULN2803A Darlington arrays for 65 cents from Futurlec. That is a total of 1.15, so I'd save $6 on the whole setup.
But the ULN2803A is way overpowered for LED's - each pin can sink 500 mA! Is there anything similar to the ULN2803A, but lower power and even cheaper?
share|improve this question
up vote 4 down vote accepted
ULN2003A are usually quite a bit cheaper, but only 7 channels.
BTW, they're not really good for 500mA, if you read the datasheet critically, you'll see it's more like 50 or 60mA per channel with all channels active, assuming a reasonable temperature range.
From the Toshiba datasheet, the lower graph is for Ta = 85°C
share|improve this answer
Cool, this is very helpful. All LEDs on for 100% duty cycle is definitely possible in this project, so it looks like the ULN2803A is not so overpowered after all. – japreiss Jun 8 '14 at 6:58
While the ULN2803 can sink 500 mA per output (with a total limit of 2.5 Amp), it will only sink what you let it - if the LEDs have resistors to limit the current to 20 mA, that's all the ULN2803 will see.
You could use individual transistors instead, but I think the convenience of a single package makes a ULN2803 a good choice.
You can get TI 16 channel constant-current LED drivers from Digi-key for cheap and you'll only need 5.
discard
