I have a dataflash memory that is too small to fit on a prototype board, so it has been put on a small board. I am having trouble figuring out where pin 1 is on this board. Below is a picture of the setup. The small circle on the chip is where pin 1 is. Underneath the large circles are the pins that connect to the board. Where on the board is pin 1? How do the lines connect to the memory? For the large circles on the right, how can they be connected to the chip if no lines can be seen going to them?
The pins on the dataflash memory are like this:
1. chip select
2. data output
3. write protect
4. ground
5. data input
6. clock
7. hold input
8. vcc
If I do a continuity test on pins 4 and 8, I should get continuity, right? What are pin combinations will work?
