Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
Given that the input of an amplifier has very high impedance, while headphones have very low one, why can I plug either one or the other on the audio-out plug of my computer?
Even with a degree on Electrical Engineering (but not analog EE), I'm still often lost when it comes to properly understanding impedance issues. Today I'm wondering how it is possible for my computer sound card to sound more or less the same when I load it with a few-ohm-impedance headphones, as when I connect it to a high-impedance amplifier that drives loudspeakers. Is the computer detecting its load to switch between two sound circuits? Or at least to adapt its impedance?
And just for my own knowledge (and assuming my sound card adapts its impedance in some way), what would happen if I plugged my headphone on an impedance-mismatched source? Would the sound sound crappy? And how crappy would it be (hashed, awful frequency response, distorted, etc.)?
Thanks!
share|improve this question
What degree and where did you get it? – Samuel Jun 9 '14 at 0:29
up vote 2 down vote accepted
It doesn't switch impedances; it's just a fixed low-impedance output. Impedances don't need to be matched for audio applications. With low-frequency audio signals, generally the voltage carries the information and the current follows along as determined by the load impedance. With RF circuitry where everything is routed in transmission lines with controlled impedances, the information is carried in the power (product of current and voltage). In this case, if the impedances are not matched, there will be issues. You can get away without impedance matching at audio frequencies because the output driver amplifier can compensate for various load impedances much faster than the rate of change of the signal. So long as the amplifier can drive the required current, there should be very little distortion. Also, the wires are generally much shorter than the wavelength, so reflections are not an issue as they might be with RF.
In an audio card, the output driver amplifier is most likely little more than a voltage follower or an op-amp with a relatively low gain, possibly with a series current limiting resistor. Let's say the amplifier can drive 100 mA and you're playing a 1 kHz sinewave that happens to come out of the card with a 1v amplitude (2v peak to peak). With no load, the voltage will not be distorted as the current required will be basically zero (it will not be because of the feedback loop and any parisitic capacitance, but the current will likely be far less than 1 mA so it can be neglected). If you attach a 600 ohm 'line in' device, the amp will need to drive a peak of 1.67 mA. If you attach a 16 ohm headset, the amp will need to drive a peak of 62.5 mA, well within its capabilities. However, an 8 ohm headset would require 125 mA, which would cause the amplifier to go into current limit and clip the peaks off, distorting the sound. Turning the volume down would mitigate this, however.
share|improve this answer
This is as easy as that for audio then... Thanks :) – Daladim Jun 9 '14 at 8:24
discard
