Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I got to code the typical example of 8 LEDS turning ON and OFF, then all getting ON in a loop.
I got a PIC 18F4550, and coded this:
    List    P=18F4550               ;Microcontrolador a utilizar
    include <P18F4550.inc>          ;Definiciones de constantes
;**********   Palabra de conficuración  *******************************************
    CONFIG FOSC = INTOSC_EC ;INTOSC_EC          ; Internal oscillator
    CONFIG PWRT= ON             ; Power-up Timer Enable bit
    CONFIG BOR=OFF              ; Brown-out Reset disabled in hardware and software
    CONFIG WDT=OFF              ; WDT disabled
    CONFIG MCLRE=ON             ; MCLR pin enabled
    CONFIG PBADEN=OFF           ; PORTB<4:0> pins are configured as digital I/O
    CONFIG LVP=OFF              ; Single-Supply ICSP disabled
    CONFIG DEBUG = OFF                  ; Background debugger disabled
    CONFIG XINST = OFF          ; Extended Instruction disabled
;******************************Variables***********************************
    conta equ 0x00
    org     0x0000
    movlw   0x62
    movwf   OSCCON
    clrf    TRISD
CICLO
    bcf PORTD,0
    call RETARDO
    bsf PORTD,0
    bcf PORTD,1
    CALL RETARDO
        bcf PORTD,1
    call RETARDO
    bsf PORTD,1
    bcf PORTD,2
    CALL RETARDO
        bcf PORTD,2
    call RETARDO
    bsf PORTD,2
    bcf PORTD,3
    CALL RETARDO
        bcf PORTD,3
    call RETARDO
    bsf PORTD,3
    bcf PORTD,4
    CALL RETARDO
        bcf PORTD,4
    call RETARDO
    bsf PORTD,4
    bcf PORTD,5
    CALL RETARDO
        bcf PORTD,5
    call RETARDO
    bsf PORTD,5
    bcf PORTD,6
    CALL RETARDO
        bcf PORTD,6
    call RETARDO
    bsf PORTD,6
    bcf PORTD,7
    CALL RETARDO
        bcf PORTD,7
    call RETARDO
    bsf PORTD,7
        bcf PORTD,0
    CALL RETARDO
bra  CICLO
RETARDO
    movlw   .255
    movwf   conta
    CICLO2
         DECFSZ   conta,F
    bra  CICLO2
    nop
    nop
    nop
    nop
    return
    end
tWhen I simulate, That code is almost working. Sometimes they get turning ON and OFF one after another starting at first led, but sometimes the sequence leaps and some random LEDS get ON unexepectedly.
I tried to add this portion of code before bra CICLO to produce the whole leds ON effect, but it just made it behave the worst.
bcf PORTD,0
bcf PORTD,1
bcf PORTD,2
bcf PORTD,3
bcf PORTD,4
bcf PORTD,5
bcf PORTD,6
CALL RETARDO
bsf PORTD,1
bsf PORTD,2
bsf PORTD,3
bsf PORTD,4
bsf PORTD,5
bsf PORTD,6
bsf PORTD,7
CALL RETARDO
This is a picture of my simulation:
What am I doing wrong? How could I make sure, working at 4 MhZ that delays will be 1 second?
share|improve this question
Hello, Diego. I'm a reviewer and I've just rejected the edit you made to Akintoyeii's answer. It's nothing personal, it's just that the correct way to report what fixed your problem is for you to post your own answer (yes, you can answer your own question, if that makes sense) or you can post a comment to his answer complementing what else you had to do to solve your problem. Then, if he chooses to do so, he can edit his own answer. – Ricardo Jun 9 '14 at 1:29
Try writing to the respective LATDx registers use only PORTD for read operations
    bcf LATD,0
This should fix your problem
share|improve this answer
@diegoaguilar I had to reject your edit as "too radical", even though the information is useful. In a situation like this, it's better to post it as a comment, rater than an edit. – Nick Alexeev Jun 9 '14 at 1:59
Code, which was proposed in Diego's edit, is bcf LATD,x and bsf LATD,x – Nick Alexeev Jun 9 '14 at 2:00
discard
