Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I need to get a ±15 V power supply and I am wondering where to find it. Should I get a 30V DC power supply in its place?
share|improve this question
well if you have two terminals for voltages for your +/-15 volts then you can add two terminals in series to get 30 V. do you have part number for that power supply! – dr3patel Jun 14 '14 at 12:53
Importantly, what do you need a ±15V supply for? What is driving this requirement? – Nick Alexeev Jun 14 '14 at 20:17
up vote 14 down vote accepted
A ±15V supply will have 3 connections (+15, -15, 0), whereas a 30V supply will only have two (+30, 0).
A 30V DC power supply probably isn't what you're looking for. You would need a way to provide a low-impedance mid-point at 15V to substitute for 'ground'-- assuming that it's isolated, or that you're very careful about how you interface it to external parts.
The best way to go is to get a ±15V supply, unless you really know what you're doing. Asking the question probably means you should just buy (or build) one!
share|improve this answer
In a ±15V power supply, you can get 3 different voltages without the need of any external circuitry -15V , 0V and +15V. In a 30V power supply, you can get either 0V (ground by reference) or 30V. I'd suggest you get a ±15V power supply.
Please help to make your answer better by making it more clear that you get TWO voltages out of a +/-15V unit and ONE out of a 30V supply. – Michael Karas Jun 14 '14 at 2:04
@MichaelKaras you get two Voltage differentials, but three voltage levels. – Passerby Jun 14 '14 at 7:22
@Passerby: Don't forget the third voltage differential you can get between -15V and +15V! – Malvineous Jun 15 '14 at 3:28
First of all you need to determine what current demand will be placed on the power supply. A ±15V supply is 2 X 15V supplies connected in series. Each supply will essentially be operating independently. It is unusual to find non-specialized power supplies with different current ratings for each rail. Depending on the load of whatever you’re connecting to it, the highest current requirement of either rail will determine the whole power supply rating. Some supplies are quoted as so many volts at X watts or Y amps. For power value multiply total voltage, 30V, by the required current to give power in watts.
A 30V power supply will not suffice if your application needs + and – supplies. Once you have determined the rating of the supply you can seek one out. I have used http://www.maplin.co.uk/
discard
