Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
EEVblog Dave shows us flush mount socketed IC's in this Tektronix 213 Portable Oscilloscope teardown, but it is hard to see and understand what exactly is a flush mount socket. Can someone explain how it is done and why?
The video at 7'46" and a picture:
share|improve this question
up vote 10 down vote accepted
Large diameter holes in the PCB with individual socket pins inserted into each, then soldered. (Either press-fit by an auto-insert machine or held together with a temporary carrier or substrate, removed after soldering. I remember seeing them on a flexible plastic strip, at 0.1 inch pitch). Essentially they use the PCB itself as the body of the IC socket.
As to why? ...
why a socket? To facilitate replacing an unusually expensive IC (look at that gold/ceramic package!) without the possible damage from soldering. Either the IC was highly stressed and could overheat, or it was unusually performance critical (matched transistors) and could drift as it aged.
why flush mount? Possibly for best HF performance : most application areas didn't pay that much attention to lead inductance or capacitance back then, but certain parts of an oscilloscope are more critical than most areas. Less likely: to keep the assembly height down!
share|improve this answer
discard
