Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I've been working through a proof but I'm stuck on one of the last steps. Consider an inverting op amp with a feedback resistor \$R_f\$ in series with a capacitor and resistor \$R_1\$
I must prove that: $$ \frac {|V_o|}{|V_i|} = \frac {R_f}{R_1} \frac {1}{\sqrt{1+\frac{f_1^2}{f^2}}} $$
My steps so far: $$ \frac {V_o}{V_i} = \frac {R_f}{R_1 - \frac {j}{\omega C}}$$ $$ = \frac {1}{\frac{R_1}{R_f} - \frac{j}{\omega RC}} $$ $$=\frac{1}{\frac{R_1}{R_f}-j\frac{\omega_c}{\omega}}$$ $$=\frac{1}{\frac{R_1}{R_f}-j\frac{f_c}{f}}$$ Now, how would I go about bringing the resistances out? (a little rusty on my algebra haha)
Thanks!
share|improve this question
You can add a schematic using the editor (shortcut: ctrl+M). It's really unclear what circuit you are trying to solve. – helloworld922 Jun 15 '14 at 5:52
You have absolute values on the left in the equation to prove. Try ((...)^2)^1/2 on you last step. – Szymon Bęczkowski Jun 15 '14 at 6:54
up vote 4 down vote accepted
Bringing the resistances out
Starting from your final equation, $$\frac{V_o}{V_i} = \frac{1}{\frac{R_1}{R_f}-j\frac{f_c}{f}}\tag{1}$$ where \$f_c =\dfrac{1}{2\pi R_f C}\$.
Let \$f_1 = \dfrac{1}{2\pi R_1 C}\$ then, $$f_c = \frac{R_1}{R_f}\times f_1$$ Applying this in \$(1)\$, $$\frac{V_o}{V_i} = \frac{1}{\frac{R_1}{R_f}-j\frac{f_1}{f}\times \frac{R_1}{R_f}}$$ $$\left|\frac{V_o}{V_i}\right| = \left|\frac{R_f}{R_1}\times\frac{1}{1-j\frac{f_1}{f}}\right|$$ $$= \frac{R_f}{R_1}\frac{1}{\sqrt{1+\frac{f_1^2}{f^2}}}$$
Alternate method
You should have started this way. Especially when you had the final answer with you. :)
$$ \frac {V_o}{V_i} = \frac {R_f}{R_1 - \frac {j}{\omega C}}$$ $$= \frac{R_f}{R_1}\frac{1}{1-j\frac{1}{\omega R_1 C}}$$ $$= \frac{R_f}{R_1}\frac{1}{1-j\frac{f_1}{f}}$$
Taking absolute value results in the required result.
share|improve this answer
Thank you, I can see where I was stuck! – Paldan Jun 15 '14 at 9:03
discard
