Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I'm running a lot of simulations in LT-Spice, and I need someway to run them all either sequentially or at the same time.
I was going to use Python, but I'm not entirely clear on how I would get past the GUI and open the netlists I have and be able to run them all and collect the data I need.
Is there some easier way to run a large ammount of simulations at once?
As an example I have about 25 models that I need to run with various transistor model files that I reference in a library folder that I swap out for every iteration. I have 4 transistor nominal models that each have different speeds that need to be tested.
Any suggestions would be much appreciated.
share|improve this question
Does it need to be LT Spice? I believe the heart of SPICE is a command line tool. – dext0rb Jun 18 '14 at 18:12
This question appears to be off-topic because it is not about electronic design. – Leon Heller Jun 18 '14 at 18:18
9
@LeonHeller on WHAT planet is SPICE not a part of design? – placeholder Jun 18 '14 at 18:21
You'll find that Monte Carlo options are perfectly suited to this. You can Schmoo different parameters and it also can display the variations. LT-Spice MAY have disabled this by SPICE natively supports this. Start there – placeholder Jun 18 '14 at 18:23
Unfortunately for me, it does need to be LT-SPICE. Thank you for the Monte Carlo suggestion @placeholder – Metal_Rainbow Jun 18 '14 at 19:15
up vote 1 down vote accepted
If it just has to be LT Spice and you can't get past the GUI I would recommend the script program AutoIt. I've used it to automate some critical Windows applications which were lacking active-x-DDE-COM.dll-whatever. You can set it up to wait for files, push windows buttons, menuitems, call programs with arguments, etc.
Have a look at:
http://www.autoitscript.com/site/
http://www.autoitscript.com/forum/
I would go for Winbatch if you want to pay for a script program.
share|improve this answer
LTSpice can be run in batch mode with the -b command line switch.
From the LTSpice Help file:
-b: Run in batch mode. E.g. "scad3.exe -b deck.cir" will leave the data in file deck.raw
How to read and interpret the .raw output is left as an excercise for the reader.
Also note, among the command line switches:
-ascii: Use ASCII .raw files. Seriously degrades program performance.
How exactly do I run it though? In command line mode that is. I'm not usually a windows user and have no idea how to do this on a windows machine. – Metal_Rainbow Jun 18 '14 at 20:56
I've never run it that way. You'll have to try it out for yourself. You can either open a command window ('cmd.exe' on the Start menu) or run it from whatever language you are using to sequence your tests. – The Photon Jun 18 '14 at 21:09
discard
