Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I've recently been given a project to lay out some PCBs which will contain a few Mini-Circuits RF amplifiers, and their associated biasing components. However, since I need to have several stages of amplification, I need inter-stage AC coupling to prevent the bias from each amplifier affecting the other amplifiers in the chain.
That said, I basically therefore need to chose series capacitors for coupling signals in the ~1.420 GHz range, and I do not really have the experience to know what I should specifically be looking for in terms of specifications.
I know I need capacitors with high Q, and probably X7R or NP0, ideally low insertion losses (S21), but I'm really feeling my lack of experience and knowledge in RF when digging through datasheets.
What are the relevant considerations for choosing parts for this kind of application?
share|improve this question
You don't need this for 1.4 GHz, but if you really want to go crazy you can try these – The Photon Jun 25 '14 at 1:10
@ThePhoton - While this project isn't too high frequency, there are several project that do use extremely high frequencies around in the lab where I work (8, 10 Ghz microwave telescopes). Those are quite interesting! And digikey even carries them! – Connor Wolf Jul 2 '14 at 0:30
The documentation for those capacitors is also fascinating. They discuss silver epoxy, and using indium solder. – Connor Wolf Jul 2 '14 at 0:31
if your application is classic narrowband rf you probably don't need the huge capacitance values, so you still don't need those fancy parts. If you're doing 10-25 Gb/s baseband digital, they're very useful. – The Photon Jul 2 '14 at 1:34
@ThePhoton - In this case, I'd be making scientific instruments. We'll make maybe 2 or 3 complete systems, so the marginal cost increase isn't worth worrying about. – Connor Wolf Jul 2 '14 at 1:48
You should be looking for capacitors that exhibit series tuning resonance well above the frequency of interest - the self inductance of the capacitor twinned with it's capacitance cause a sharp series resonance. Take a look at this graph from AVX for their MLCC NP0 range in 0805 size: -
More than likely the 10pF will exhibit resonance around the 2 GHz mark. I'd say you either make use of this (because, as an AC coupler it'll still block DC just fine) or find a better grade but for sure you are going to find a lot of caps resonant in the GHz region you want to operate at.
share|improve this answer
The main thing I'd add to this for future readers is, generally, smaller packages have lower parasitic inductance, so an 0402 will have higher resonant frequency than an 0805. – The Photon Jun 24 '14 at 20:38
@ThePhoton very true – Andy aka Jun 24 '14 at 21:04
discard
