Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
In the figure, if I = 80 mA, determine the resistance R.
Answer is 600Ohm.
My Steps :
$$ I2=-0.08$$ $$20+R\left(I1-I2\right)+100I1=0\tag1$$ $$200I2+40+R\left(I2-I1\right)=0\tag2$$
So $$20+R\left(I1+0.08\right)+100I1=0\tag1$$ $$24-R\left(I1+0.08\right)=0\tag2$$
Then $$ R\left(I1+0.08\right)=24\tag{a} $$
Now I sub (a) to (1) and get $$ 20+24+100I1=0\\ 100I1=-44$$ $$I1=-0.44\tag{b} $$
Sub (b) back to (a), $$ R\left(-0.44+0.08\right)=24\\ R=-66.67 \Omega\\ $$
How to obtain the answer 600 Ohm?
share|improve this question
up vote 5 down vote accepted
The answer is definitely wrong. Here's a quick way to tell. If you have R=infinite, then you have 40V/300ohms = 0.133 amps if you ignore current provided by the 20V supply. That's the absolute minimum current that will flow through I. Any lowering of R from infinite will only increase the amount of current flowing through I. That means that their initial statement of I=80mA is impossible.
The only exception to that is if we do allow negative resistances as you have calculated. A negative resistance would be kind of like a voltage/current source. You're likely correct in your negative resistance calculation.
share|improve this answer
If R is infinite, there's 60V / 300 ohms. – Ben Voigt Jun 26 '14 at 21:25
@BenVoigt I originally used 60V, but that voltage could potentially drop as R lowers from infinite due to the 20V dropping across it, so it's more solid to ignore the other 20V because it only adds to the current. 40V/300 still is way above the 80mA the problem offers. – horta Jun 26 '14 at 21:33
To be sure, the current \$I\$ is independent of \$R\$ and equal to \$200\mathrm{mA}\$ except for the special case \$R = -\frac{200}{3}\Omega\$ which allows \$I\$ to be any value. – Alfred Centauri Jun 26 '14 at 22:29
@AlfredCentauri Understood, your way is definitely the proper way to do it. My way is simply a sanity check. – horta Jun 27 '14 at 0:03
@horta, I'm all for sanity checks and I do understand your calculation and superposition like approach. The 20V source can only increase the current so you've set a lower bound on \$I\$ (assuming \$R \ge 0\$). – Alfred Centauri Jun 27 '14 at 0:19
Actually, in this circuit, the current \$I\$ is independent of the resistance \$R\$.
To see this, remove \$R\$ from the circuit and calculate \$I\$:
$$I = \frac{20V + 40V}{100\Omega + 200 \Omega} = 200\mathrm{mA}$$
Interestingly, this implies that the voltage between the nodes where \$R\$ was connected is:
$$20V - 200\mathrm{mA} \cdot 100 \Omega = 0V$$
This means that we can add \$R\$ back to the circuit and the solution doesn't change since there is no voltage between those nodes.
Thus, there is no value of \$R \ge 0\$ that will yield a current \$I = 80\mathrm{mA}\$.
However, if we allow \$R < 0\$, we have the interesting possibility of an infinity of solutions!
Writing a KCL equation at the top of \$R\$ yields
$$\frac{V_R}{R||100\Omega||200\Omega} = 0A$$
For \$R\ge 0\$, the only solution is \$V_R = 0\$ as derived above.
But, if we allow
$$R = - (100\Omega||200\Omega) = -66.67 \Omega$$
the denominator is infinite and thus, there is a solution for any \$V_R\$ and associated \$I\$!
This shouldn't actually be too surprising. The Thevenin equivalent circuit 'seen' by the resistor \$R\$ is given by
\$V_t = 0V\$
and
\$R_t = 100||200 \Omega = 66.67 \Omega\$
If we then parallel this equivalent circuit with an \$R = -66.67 \Omega\$ resistor, the new Thevenin equivalent becomes an open circuit.
This means that we can place a voltage source across \$R\$ and the voltage source will not supply any current.
In other words, we can temporarily place a voltage source across \$R\$ and, since the source supplies no current, remove the source and the voltage across \$R\$ will not change - the circuit will maintain that voltage across \$R\$.
Of course, there are no physical negative resistors (though we can approximate them with active circuits) so this is mostly academic.
discard
