Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I would like to ask for some help regarding a stepper motor I would like to use. I need 1 deg step and as I have seen there is no such stepper. Could you advise me as an amateur the way i could bring this down from 1.8 or bring t up from 0.9 . What is easier and less complex?
Thank you,
John
share|improve this question
IMO the best advice it to reconsider your 1 degree requirement. Where does it come from? – Wouter van Ooijen Jul 6 '14 at 10:03
One way to increase the resolution so that you can make steps close to an exact one degree is to use a microstepping driver.
That kind of driver works by PWM-modulating the current to the motor coils in a ratio that allows the rotor to stabilize in a position between the poles. You can't really increase the resolution by a huge factor, despite the driver stepping in (say) 128 or 256 microsteps but it might be good enough for you.
If you had 8 microsteps on a 1.8 angular degree motor, then each step would represent 0.225 degrees, and every 40 microsteps (9°) you'd be back to an exact full step.
You can make your own, or there are commercial suppliers such as Gecko.
share|improve this answer
One way to change the step size is with a gear box. If you had a 1.8 degree stepper motor and used a gear box with a input to output ratio of 1.8::1.0 you would achieve what you want. There are two price you pay for this. First off a gear box can introduce backlash which shows up in motion as a latency at change of direction. The second price is that the stepper motor has to run at a faster rpm that the output will achieve.
An advantage of the gear box is that it will give you a mechanical torque increase at the load over the direct drive approach comparing both cases with the same motor characteristics.
He wants advice "as an amateur way" on how to do this. A custom gearbox does not really seem "easier and less complex". – WhatRoughBeast Jul 5 '14 at 23:27
Building your own wouldn't be all that difficult, for low torque applications. – whatsisname Jul 7 '14 at 15:09
Thank you for your response and analytic information.
What I have found for anyone that will need something like I did, look at this :
http://www.omc-stepperonline.com/gear-ratio-91-spur-gearbox-high-torque-nema-34-stepper-motor-34hs384004dsg9-p-195.html
J.
To respond to other's posts, please post as comments (once you have sufficient reputation for this), or as edits to your question - This space is reserved for actual answers to the questions. – Anindo Ghosh Jul 7 '14 at 12:34
@AnindoGhosh: This is an answer to the question. – Dave Tweed Jul 7 '14 at 12:54
Sorry, I should have been clearer. My point relates to "Thank you for your response and analytic information." – Anindo Ghosh Jul 7 '14 at 12:57
discard
