It's not responding to the programmer at all in avr studio.
avrisp attiny44
mosi -- - mosi
miso ---- miso
sck ---- usck
reset ---- reset
Or can it not be programmed by an mk2? I assumed all chips can be programmed by it
Or can it not be programmed by an mk2? I assumed all chips can be programmed by it |
The AVRISP mkII can program the tiny44 in the latest version of AVR Studio (4.18 SP3 or 5 beta). Make sure your version is either up-to-date or check the help files/release notes that came with it to verify. Also allow AVR Studio to update the firmware in your AVRISP mkII if it needs to. Verify the following conditions:
Follow the troubleshooting guide in the AVRISP mkII user guide [PDF] if you experience problems as a first step:
