Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
I'm using the picdem 18F4550 with microchip v8.63 with the C18 compiler.
I will enable PortA to set as input, I will connect a LDR on port RA0. Which is as following (I think):
TRISAbits.TRISA0 = 1; //<= set RA0 as input.
Now I want the value of the LDR (voltage/value if a led is on), can I say:
int colorLed = PortAbits.RA0;
And now in the variable of type int there is the value/voltage of my Led.
Correct me if I'm wrong.
share|improve this question
up vote 7 down vote accepted
Firstly, lets check that you have connected your LDR up correctly, it should be something like this...
LDR wiring
To read the value of PIN RA0/AN0, you need to do some initialisation to make sure the port is setup correctly. The datasheet explains how all this works, but these values should work:
TRISAbits.TRISA0 = 1;           // Set RA0/AN0 to input
ADCON0           = 0b00000000;  // Set channel select to AN0
ADCON1           = 0b00001110;  // Configure RA0/AN0 as analogue
ADCON2           = 0b10101010;  // Right justified result
                                // TAD 12 and FOSC 32 - may need to adjust this
                                // depending on your clock frequency (see datasheet)
ADCON0.ADON      = 1;           // Enable ADC
Now the port should be set up, you can now read the LDR value:
ADCON0bits.GO    = 1;           // Set the GO bit of the ADCON0 register to start
                                // the conversion.
while (ADCON0bits.GO);          // Wait until the conversion is complete.
You can now read the result of the LDR as a 10-bit value in ADRESH:ADRESL. If you only need 8-bit resolution, then set ADCON2.ADFM = 0 for left justification of the result, then you only need to read the ADRESH to get your result.
share|improve this answer
the plan that you signed, correct. The code that you write is what I wanted! Many thanks for your help!!! – yannick Apr 4 '11 at 16:39
To read an analogue voltage you need to use the PIC's ADC (Analogue to Digital Converter).
Here's a tutorial: http://www.roboticsguy.com/tutorials/pic-microcontrollers/configuring-the-pic18f4550-10-bit-adc-module
Very helpfull ! thanks! – yannick Apr 4 '11 at 16:48
discard
