Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
as an exercise problem in ARM assembly program, I had to convert a number x to its absolute value. now seeing the problem as a simple problem of removing the sign of the respective number, I used BIC instruction to clear the MSB sign bit. later on I found out that RSBMI instruction is present in ARM to compute the absolute value of any number.
my query is that what is the difference between these two methods employed, does BIC and RSBMI present any different result in some cases? or if it can be done by just BIC then why add an RSBMI in RISC instruction set?
share|improve this question
Your BIC would work if values were represented as sign-magnitude. Instead (nearly?) all computers use 2's-complement. – Wouter van Ooijen Jul 20 '14 at 9:37
up vote 3 down vote accepted
Which yields wrong results, of course. Example (in 8 Bit): -1 = 0xFF, sign bit set to zero: 0x7F => +127 instead of +1.
share|improve this answer
discard
