Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
This question already has an answer here:
Just curious as to why do non volatile memories like EEPROM in an AVR have a write limit ?
Also is this limit per location/adress in the memory or on the memory as a whole ?
share|improve this question
marked as duplicate by Dave Tweed Jul 21 '14 at 0:58
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
24LCxxxx series EEPROMs and built in EEPROMs in the PICs have a limit per location. I don't this is the case for all models of EEPROM, though. – Nick Alexeev Jul 20 '14 at 22:50
If the erase cycle erases one location then it's per location, if it's a block, then it is per block. I think so anyway. S08PT60 (Freescale 8-bit MCU), for example, have a two byte erase sector. – Spehro Pefhany Jul 20 '14 at 22:57
@SpehroPefhany, I know that when I program AVR controllers there is an option to erase the entire EEPROM, but I have not seen much regarding erasing blocks like in flash. Perhaps I have just done too little with EEPROM. – sherrellbc Jul 21 '14 at 0:30
It is due to the process of how the memories work.
To write a value the threshold of the device is shifted by storing charge in a floating gate that lies between the control gate and the channel. The process of injecting and removing charge stresses the gate oxide to the point where it leaks , just ever so little. the problem is that this process is slightly damaging and the effect is accumulative.
The wear-out is roughly proportional to number of write/erase cycles with variation on a bit by bit basis.
share|improve this answer
