In a project, I want to measure weight with the resolution of 1 gram. Things I want to weigh, are max of 6 grams and I need to diffrentiate between a 5 gram thing and a 6 gram thing.... So I would require a Load cell with resolution of 1 gram.
I searched in Local Market as well as online but I couldn't find a good one.... Can anybody have suggestions what can I do?? Or Links where such load cells are available will be way good....If anyone used such load cells then...then I would be the happiest person on earth! :)
Thanks!
P.S. I been to omega.com but these are very costly.... If no other alternative.... I have to choose them or close the project.... Second option would be easy for me! :(
link|improve this question
56% accept rate
have you considered finding a cheap gram scale and taking out the load cell out? usually I see them accurate down to +-.1 grams. – jsolarski Mar 29 '11 at 11:08
@jsolarski Good Idea!! Thanks!! – Swanand Mar 29 '11 at 12:54
@jsolarski - I guess display resolution is 0.1 grams; I seriously doubt that you get that kind of precision from a cheap kitchen scale. It's like digital fever thermometers. They usually display to 0.01 degree centigrade. That's not the precision, though. Not for a 10 euro thermometer anyway. – stevenvh Mar 29 '11 at 17:24
@stevenh Accuracy depends greatly on the calibration of the circuit and how they measure the load cell. Yes a cheap load cell will have worse characteristics then a High quality one. This is why Scales are calibrated with standard Weights either at the factory or a built in function and I don't see why you couldn't get even Higher accuracy using a better ADC then one in the hacked scale. – jsolarski Mar 30 '11 at 7:10
@jsolarski: it's an illusion to think you can get any precision you want just by calibrating. That would require all components to be perfectly linear, which isn't the case. Every system has its practical limitations which can't be fixed with calibration. – Federico Russo Apr 24 at 8:03
feedback
1 Answer
up vote 2 down vote accepted
As stevenh pointed out, cheap scales may not be that accurate, compared to there "box values" If you are just using a load cell from it you should be able to get at least the same and or better accuracy if you have a sufficient design for your ADC and cell combo. To get even better results i would suggest getting a small set of standard weights to calibrate your device.
link|improve this answer
Instead of Buying a Gram scale, I went to it's service station and enquired about the internal circuits and from where they get these load cells.... Fortunately those guys were enthusiastic and gave me lots of info!! Thanks @jsolarski for this idea! – Swanand Apr 5 '11 at 8:57
Care to share that information? – user4385 May 24 '11 at 4:46
what information are you looking for? – jsolarski May 25 '11 at 1:37
feedback
or
required, but never shown
