Tell me more ×
What's the cheapest way to detect vibration with Arduino?
What's the vibration sensor that I need?
I want to detect PING PONG NET vibration and light on led if touched.
share|improve this question
Can you be more specific? Depending of what you wanna do, maybe it's not necessary to use a vibration sensor. – Daniel Grillo Mar 29 '11 at 12:30
@Daniel See edit. – elpsk Mar 29 '11 at 12:35
up vote 3 down vote accepted
Piezo sensors are cheap, reliable and designed for the purpose you suggest - arduino tutorial
In the uk, bitsbox has one for 75p. You can probably find others cheaper, or salvage from electronic toys.
EDIT following poster's clarification of use: Sound is vibration through the air, I see no reason why a piezo sensor cannot accomplish what you suggest, but the form factor may not be ideal for fixing to ping pong nets! I think a flex sensor would be more suitable, sewn into the top of the net.
share|improve this answer
Can i use piezo to detect if the ball touch or not the pingpong net? Or it detect only vibration sound? – elpsk Mar 29 '11 at 12:40
An optical or magnetic sensor mounted mid net, bottom edge might be a good way to acomplish this. Might also detect vibrations in the table, as might any sensor.
discard
