Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
When I put it in the outlet it "popped" with some oily gray smoke. Honestly I thought that the voltage rating on the capacitor meant you could feed at least that much voltage through it, but clearly I'm missing something fundamental.
I am glad I tried this with a rubber gripped wrench.
share|improve this question
14
In addition to @Barry 's correct answer, most electrolytic capacitors are polarized. That is, they have a positive lead and a negative lead. If you hook them up backwards, they can fail violently! When attaching a polarized cap to AC, this applies a negative voltage for half of the time, which may be another reason your cap failed. – bitsmack Jul 25 '14 at 3:03
@OlinLathrop What's "Alternating Current voltage" then, and how is it different to "Alternating Current current"? – OrangeDog Jul 25 '14 at 14:31
@JohnU While it would have been better to use a blast shield, and a remote switch to connect the capacitor, I don't think that this is a sign of idiocy. At best lack of proper planning and foresight, at worst incompetence. Mains voltage can kill you but it is incorrect to say that it will kill you. Far more people have come into contact with mains voltage and lived than have died from it. Of course he'd be pretty unhappy if he lost his sight due to the exploding capacitor, and that's actually a more pressing concern than electrical exposure. – Adam Davis Jul 25 '14 at 14:32
8
@AdamDavis - I was simplifying out of some possibly misguided attempt to save Samwise from himself. Best to assume mains voltage WILL kill you and avoid pratting about with it until you know enough to know better, than assume you will likely be OK - you only get one chance to be proved wrong. Usually I don't interfere with the best efforts of natural selection but it's Friday and my boss left me in charge of the donuts. – John U Jul 25 '14 at 14:54
6
@JohnU I'm not going to disagree it was a stupid thing to do, however I'm more than willing to come forward and admit (post on a forum like this) to doing a stupid thing if it means others can learn from it. – samwise Jul 25 '14 at 16:07
up vote 16 down vote accepted
The voltage rating on an electrolytic capacitor is for DC, not AC. The impedance of a 10 uF capacitor at 60 Hz is 265 ohms so it would draw about 0.45 amps. The combination of too much voltage and too much current will result in destroying the capacitor. In most applications of such capacitors, they follow the output of an AC to DC rectifier so they see an AC ripple voltage on top of a relatively high DC voltage. The ripple voltage will cause current to flow through the capacitor but it will be much less than what you subjected your capacitor to because the ripple voltage is only a fraction of the full AC input voltage. Most electrolytic capacitors have a maximum ripple current rating to prevent overheating. The voltage rating gives the maximum of DC + AC ripple that the capacitor can withstand. In general this should be derated by at least 25% to protect the capacitor and increase reliability.
share|improve this answer
12
This is all true, but not the cause of the cap exploding quickly after being connected to the AC line. The real reason is that half the AC cycle will drive the cap with significant negative voltage, which electrolytic caps can't handle. – Olin Lathrop Jul 25 '14 at 11:42
@OlinLathrop What evidence do you have that it was polarized, or electrolytic (other than it exploding, of course)? This answer could be correct. It could also be because the capacitor was faulty. There are a number of ways it could have failed and not been electrolytic, or polarized. – Adam Davis Jul 25 '14 at 14:13
12
@Adam: The circumstantial evidence is overwhelming. First the vast majority of 10 uF 450 V caps someone will find lying around will be electrolytic. Second, any other technology would be physically large and would be able to handle the ripple current. It's really not that high at 60 Hz. Even if not, it would heat up slowly, not explode within a few seconds after being connected to the power line. – Olin Lathrop Jul 25 '14 at 14:27
discard
