Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. Join them; it only takes a minute:
Sign up
Here's how it works:
  1. Anybody can ask a question
  2. Anybody can answer
If used as a LED sink, what happens if a 74HC595 pin goes high? Might the LED blow?
I expect that when a pin is low, current will sink and the LED will light.
What about the opposite condition? When a the pin goes high, might there be risk of blowing LED's due to reverse flow? Why or why not?
share|improve this question
up vote 6 down vote accepted
The answer lies in the reverse voltage rating of the LED chosen. Common through-hole LEDs typically are rated at 5 Volts reverse, some LEDs higher. This means that for up to 5 Volts applied in reverse bias, the LED will behave as a regular diode, blocking current flow. Beyond this voltage, reverse breakdown might occur, potentially destroying the LED if the voltage is high enough.
In the schematic shown, the PWM signal is 0 to 5 Volts. Thus, even when the PWM signal is low, and the latch output is high, the maximum reverse voltage the LED is exposed to is less than 5 Volts. So the LEDs will be fine.
share|improve this answer
Being a diode, your LEDs will not suffer any damage, provided that the voltage being applied is below is breakdown voltage. +5V is generally safe for diodes commonly used.
Gah, beat me to it! – fuzzyhair2 Jul 30 '14 at 15:06
+5V will make most LEDs DED (Dark Emitting Diodes). – Spehro Pefhany Jul 30 '14 at 15:31
Almost all LEDs are rated for at least 5V reverse voltage.
In actual practice, I've never seen one that broke down even at 12V.
(Pulsed) reverse bias is a normal operational condition for multiplexed LED displays.
discard
